Discuss RCD problems in the Periodic Inspection Reporting & Certification area at ElectriciansForums.net
M
Modernelectric
I have fitted a dual rcd board, and everything has tested fine. my only problem is that the rcd's do not trip on the 180 phase roatation, but trip within limits on the 0 phase rotation. I have swapped both rcds for new to check that the rcd's werent faulty and i still have the same problem.
Has anyone had any problems like this? any clues because this one is ****ing me off.
thanks!
Yes ive used it on other installs and its fine, its only a few months old, it seems no one else has encountered this problem then?! its a mystery to me.
Reply to RCD problems in the Periodic Inspection Reporting & Certification area at ElectriciansForums.net
Hi everyone, I have been asked to pull in some new 3 phase supplies for 7 new welders which do not require a neutral connection. The client has...
Hi, I have lifetime experience (50+ years) in United States with basic knowledge of split phase 120/240 volts replacing wall switches and...
I have just checked a double outlet and it trips at 18ma. It was supposed to be faulty. Washing machine had a bad heater which got replaced but...
Cant get my head round this :( I understand N-E faults cause RCD's to trip, but I cant understand why on these 2 occasions, googled allover but...
