Discuss Rcd protection for domestic inatalls. in the Electrical Forum area at ElectriciansForums.net
That's my understanding of the regs now that's why in a split RCD consumer unit Hager are fitting 100A RCD's by default.Hi guys. Am I right in interpreting the regs with regards to rcds that they need to be rated equal to or higher than the main supply fuse? So not to overload them? Or am I reading it wrong?
Thanks on advance.
It's up to the installer how the install complies. A total potential load after the RCD less than the rating of the RCD will comply. If the potential load exceeds the rating of the RCD, an OCPD before the CU less than the rating of the RCD will comply.The trouble is only hager have done this and none of the other manufacturers seem to have followed suit. So cant see how they comply?
Sell the RCBO's... we are electricians and we know what is right. Split load boards belong in the 80's. Things have changed, DC leakage current / electronic equipment. I don't compete with the flooding of the market with £60 complete (split load AC RCD's) boards. Explain the difference - give the option and if they want to fit the cheap board - find someone else to do it.But what if customer dont/want the cost of rcbos
if I could give one piece of advice - it would be this (type A RCD obviously)...Just fit rcbos....
Lewden... fitted a couple so far. Good price, nice quality, loads of room and a spare SPD slot right at the end (longer than the busbar). The only thing I don't like are the square grommets but hey, I'm warming to them.Well that's the thing I cant seem to find any manufacturer that does a type apart from hager.
Hager do type A RCDs and RCBOsWell that's the thing I cant seem to find any manufacturer that does a type apart from hager.
Lewden do type A RCBOs
Wylex do type A RCDs and RCBOs
CP fusebox do type A RCBOs and are a cheap and popular option at the minute.
SBS trade sales do type A RCBOs
There are probably others too.
I've been using Lewden RCBO boards for a couple of years or more now. Can't complain at all, apart from maybe their SPD could be a bit cheaper.I should confess, I'm a pretty new Lewden 'fanboy'. but really like Wylex too. The only brand I'm beginning to loath (for CU's) are MK - who should be top. Their boards are rubbish (IMHO) now (for 18th) - everything else they make is great but they are falling behind big time - don't even make an SPD yet - but endorse Surge Protection Devices for use in their boards... messy!
Reply to Rcd protection for domestic inatalls. in the Electrical Forum area at ElectriciansForums.net
