Discuss RCD Protection or not???? in the Canada area at ElectriciansForums.net
hoppy
Hi,
got a 3 phase transformer on a construction site (office refurb) fed by 6mm swa, form an old 3 phase d/b.
Should the swa to the transformer be rcd protected or not, the regs are not really clear on this?
The cable is tied up and taped with caution markings.
Craig
When I worked on temp sites everything was RCD protected as even marked ,tied out the way,brought up on inductions this cable WILL get damaged
Im assuming the tranny is a big multipul outlet type I know its "Bad practice " ect ect but I always put an earth strap round armours ( bonded to frying pan ) at transformers as transformers get moved ,bashed,ect on sites and no matter what you do the gland may come undone leading to core damage at entry Also to assist this dont strip the inner covering back to the gland but leave it well inside
Reply to RCD Protection or not???? in the Canada area at ElectriciansForums.net
Hi everyone, I have been asked to pull in some new 3 phase supplies for 7 new welders which do not require a neutral connection. The client has...
Hi all, I am at odds on whether RCD protection is required on an SWA of 14 metres, clipped direct under flooring direct from CU to an exterior...
I'm doing a college design project and need to choose a suitable range of circuit protective devices for the whole contact. I've chosen and...
I'd appreciate a quick sanity check, thanks in advance: New circuit for a 3 phase cooker, in a community centre (run by a charity). Total load...
For context i am in my 2nd year in college and my head is going round in circles a question in my project for which i need to select the right...
4K
