Discuss RCD protection to outbuilding in the UK Electrical Forum area at ElectriciansForums.net
Not 100% sure on the requirements for RCD protection of outbuildings. I am going to run 10mm2 SWA, about a 20m Run, to a sub board in the outbuilding, buried in the ground. The main house is on a TN-S, and the outbuilding will have a 32Amp hot tub, a few small fridges, a couple TV's, sockets and lights. Do I have to RCD protect the supply from the main board in the house, or can I just protect my individual circuits from the sub board?
Cheers
If the SWA is installed correctly then there's no need to provide that sub circuit with RCD protection, but you absolutely WILL need it for all circuits being fed. Also - check manufacturers requirements for supplies and earthing regards the hot tub.
and get some deeper pockets for when the leccy bill comes, powering that glorified pond.
Reply to RCD protection to outbuilding in the UK Electrical Forum area at ElectriciansForums.net
Hi all, I am at odds on whether RCD protection is required on an SWA of 14 metres, clipped direct under flooring direct from CU to an exterior...
Hi everyone, I have been asked to pull in some new 3 phase supplies for 7 new welders which do not require a neutral connection. The client has...
So as the title says can I use a mcb as the main switch. Basically to keep it short I’ve took a 25mm sub main to power an outbuilding. Mains...
As the title says, I am looking for a recommendation for an enclosure and gland arrangement to electrically isolate or divorce the earth/armouring...
5K
The earthing arrangement where the hot tub will be installed is formed in the TN-C-S system. I want to install the sub-main distribution circuit...
