Discuss RCD Quandary. in the UK Electrical Forum area at ElectriciansForums.net
telectrix
Mentor
basically, done a EICR for rental. 12 way wylex with 3871 MCBs, no RCD at all, so a few C2's and C3's. ideal world is a new CU with RCBOs, or even a dual RCD board. landlord won't pay more than necessary as it's a short term let and due to be demolished as soon as he gets planning for 2 houses on the land. upfront RCD would get rid of the "fails" on the installation, but 1 rogue circuit and the lot is dead. what would you do?
Not that.
Either upgrade the consumer unit, as it could well be a long time before the property gets demolished, and the law is the law, and it cannot be let with C2s.
Or maybe (assuming RCBOs for this board are not available) run the circuits that need RCD protection through a separate enclosure with RCBOs in it.
be hard enough getting the tight-arse to pay for an upfront RCD in enclosure. mention RCBOs and he has a heart wallet attack. the upfront RCD would get rid of the C2s so would make it safe for use, but non-compliant regarding division of circuits.
I hate fitting dual rcd boards but if the property is to be demolished in a few months time I would be inclined to by a second hand rcd board off eBay and fit that as a very temporary fix
you can pick up a dual rcd board for about 30 quid second hand
your customer probably won’t like my Labour charge for doing it , but if it’s an easy swap then you can bill him half a day
You asked what we would do.
If the owner is unwilling to pay to comply with a legal requirement, I'm off down the road to the next job...
A completely different way of looking at it - One day when he has new houses built (which he claims is soon) he will need a new consumer unit with rcd and probably spd protection to get past building control. No reason I can see that it can't be removed and preserved when demolition occurs.
Granted the labour costs of a board change are higher than an up front rcd but he has to suck that up as he's a landlord and responsible for his tenants safety.
right then it's ÂŁ450 for a new CU, add my time and effort, another ÂŁ300 - ÂŁ350, end of the day, it's less than 1 month's rent.
if the guy is penny pinching just sling in a cheap screwfix special duo rcd board or buy one off ebay
think that's what he'd go for a 13 way BG dual RCD board. but then he'd want it refitting in 1 of the new houses. not my problem. i'll be out of the game by then (assuming i'm still alive enough to be fed Theakstons by straw).
In all seriousness I'd rather fit that ÂŁ80 delight than nothing at all (once the knock-outs have been removed with dynamite)
them rear knockouts are a gem. i finf a 2lb hammer and a sharp cold chisel the easiest.
Don't trust any landlord that says it's going to be a short term let, the amount of paperwork and certificates needed to rent out a domestic property now days make short term letting very unprofitable, its so easy for a Landlord to say "Oh there was some planning problems" and two years later they still have not been resolved, don't get suckered in, it's your signature on the EICR.
Reply to RCD Quandary. in the UK Electrical Forum area at ElectriciansForums.net
Firstly sorry if this has been asked before. Carrying out alot of EICRs because of the new rental laws. Keep coming across boards with just one...
Hello, I'm after some coding advice / opinions regarding EICR of warehouses / offices. In others opinion would this be agreeable (helplines closed...
I know how I was taught to test a RCD, 6 tests in all two no go, two under 300 mS and 2 under 40 mS with no load. But thinking about it not so...
Doing one more of the flood of EICR today on a rented property before a tenant change, but ran into a slightly interesting case so would...
12K
Just a rant regarding all these landlords EICRs that have become the in thing. And maybe a word of caution to all of you doing them. To kick off...
11K
