B
beckryl
Hello fella's, here's one for you.
First post from me and I'd like to know any ideas.
I went to a job today where the guy has had a new M2 board installed. Guy previously fitted m2 rcbo (6a) to a lighting circuit (no problem), 1mm live and neutral and earth going off to circuit (no problem).
Only 5 lights on the circuit.
A couple of weeks ago he pressed the test button and a small puff of smoke came from inside the rcbo. Then he reset it and the breaker works only as a switch(maybe as an mcb).
He then called me (a friend) so I today popped over thinking it was a faulty rcbo which wasn't tripping. I replaced the rcbo and pressed the test button and yes there was a small puff of smoke and the rcbo worked only as a switch(mcb?)
So now I'm going to have to go there and do a test etc on the circuit and figure out what has happened. (not my job but the guy has disappeared off the earth). I didn't have my test gear on me so didn't do anything.
I'll go back in the next day or two.
There is a test cert in the property which all looks cool.
Any ideas?????
Any ideas?????
