P
pastitsparky
Hi Guys, now here's a strange fault.
I have recently installed a new split MK consumer unit.
All circuits have high IR and the RCDs were tested by a Robin tester from all sockets and oven and lighting circuits etc, all good.
When I switch "off" my garage lighting, which is 3 fluro fittings the RCD trips on occasions, I suppose I could disconnect each fitting one at a time to see if the problem stops.
Any ideas would be appreciated.:wink5:
