Discuss RCD Testing at CU in the Periodic Inspection Reporting & Certification area at ElectriciansForums.net
C
chrisgc
Hi
Whats the method for testing RCD's at the consumer unit (as opposed to plug/socket method).
I have a Metrel MI3000 Easi Plus tester which is either 2 or 3 lead tester.
Green lead on earth bar and red lead on the line terminal of the load side of RCD, press button and waits for it to finish the tests.
Thats how its done on a Megger 1552 anyhow.
Reply to RCD Testing at CU in the Periodic Inspection Reporting & Certification area at ElectriciansForums.net
Hey Is there any fans of Meterel ? What do you think of the one below ...
I just finished a garden room supply. The customer already had a CPN garage consumer unit that the last sparks left there, brand new in box, and...
I live in Australia; you can use a socket tester to test the RCD for the power outlet circuit. Plug device to a 3-pin wall socket, set testing mA...
Hi I’m just starting to do ev chargers so it’s looks like I need new tester. I currently have Megger 1711. So I can’t do a 6ma rcddc test. I...
