Discuss rcd tripping in the UK Electrical Forum area at ElectriciansForums.net
R
roughandready
hi guys ,several pieces of equipment on different circuits on the non rcd side side of a split main/rcd board are tripping the rcd .the mcbs
are not tripping.
any ideas as to why this is happening? could it be crossed neutrals or just a faulty rcd.thanks
disconnect all items on circuits, this may include outside lights, pond pumps etc and then see if rcd trips. aafter doing this start thinking about ir test and faulty rcd.
ps don't leave pump off for too long
Are you sure you've connected the neutrals to the correct bars?
More to the point when was the board last working properly and who's been meddling!
Sounds like a crossed neutral to me but I don't understand why it should start all of a sudden or is it a new installation?????
Have you just started using an immersion heater perhaps?
Has the client wire up any plugs?
I had a situation where the RCD kept tripping and the microwave plug had been wired neutral to earth, earth to neutral.
Thought at first that the circuit cable had been damaged.
Just to confirm do you mean that the circuits on the non-rcd side are tripping the RCD??
I take you have isolated the MCBs on the RCD side and still getting tripping there - you could have a low resistance on the N/E of the RCD side - try an IR test N/E on the RCD side then look for borrowed neutrals as that could also trip the RCD.
Also when did this start?? what happened? is it a new build/rewire/new cu??? All these would point to the CU not being wired correctly.
Also what state is CU in?? (the wires)
Reply to rcd tripping in the UK Electrical Forum area at ElectriciansForums.net
Cant get my head round this :( I understand N-E faults cause RCD's to trip, but I cant understand why on these 2 occasions, googled allover but...
An RCD keeps tripping. Please see attached photo of the board (2 photos attached). I’ll call the breakers: MCB (1) marked ‘Upstairs lighting’...
Called out to fault on RCD tripping maybe twice in a month for sometime. Did all the tests & found RCD was faulty, Refitted a new Rcd Type A which...
I have just checked a double outlet and it trips at 18ma. It was supposed to be faulty. Washing machine had a bad heater which got replaced but...
I'm writing this mainly hoping something occurs to me while writing it! I got called to an occasionally tripping RCD. It's a Hager double height...
