Discuss RCD won't trip in the Australia area at ElectriciansForums.net
shovelhead
Hi
can anyone help.
I have just done an extension to an annexe, using 3 core 1.5mm swa for the lighting and 4 core 2.5mm for the ring into a 2 way CED Garage Consumer Unit with a 63A 30mA RCD, 32A and 6A MCBs.
Ze, Insulation resistance and continuity test came out fine testing with a Megger MFT 1553 but the RCD will only trip at 5x.
Any advice please?
first try testing at the RCD, loads isolated.
Ill have a guess, remove bus bar and do a three lead test on the load side terminal screws and see if it trips. This means your rule out any possibility of it being down to the circuit(s) your testing. Coreect me if im wrong though :D
No need to remove busbar. Switching off circuit breakers will do.
Reply to RCD won't trip in the Australia area at ElectriciansForums.net
I just finished a garden room supply. The customer already had a CPN garage consumer unit that the last sparks left there, brand new in box, and...
Good evening, I have recently moved into a new home and I am having problems with the MCB/RCD tripping (Mem M6 Type 3 - 30mA). It intermittently...
Hi all, So I’ve been having a strange fault in my house which has just appeared over the past few days. About a month ago I moved my pc set up...
14K
Had a real headache of a fault finding job which has left me scratching my head - RCCB on a split load board, supplying 3 circuits (shower...
4K
Hi all,looking for some pointers to an RCD problem, I work entirely on large poultry farms, I've only been in post a year, at some point before I...
