Discuss Recessed Can Light Problem - help needed in the DIY Electrical Advice area at ElectriciansForums.net
diydanny
I have a recessed can light (Halo H7ICT) that recently stopped working. I checked the breaker, tried a new bulb, and ended up replacing the socket with a new one but none of that worked. I have another light that is on the same circuit I think, same fuse, that is working just fine. I'm wondering what the next step might be? Thermal protector? Should I replace the whole housing? Was really hoping to fix this one.
Thank you in advance for your wisdom!
Dan
Dan
If you've tried all of those things and the light still isn't working, it could be the thermal protector. You could try replacing the whole housing, but it might be easier (and less expensive) to just get a new recessed light. On How to change a recessed light bulb? - https://lightovo.com/post-how-to-change-a-recessed-light-bulb/ you can read an article about how to change recessed light bulb.
Reply to Recessed Can Light Problem - help needed in the DIY Electrical Advice area at ElectriciansForums.net
Hi everyone, after temporary removing a Sonoff that I've installed years ago to do some painting, I'm unable to get everything back to work. I've...
I have two 4 inch recessed CLF 4 pin light cans installed in laundry room since 2012. The bulbs are fluctuating in brightness. I think the...
My kitchen has track lighting. It consists of three halogen light bulbs. I've had the fixture for more than 25 years with no issues. Last night...
