Discuss recessed downlights - recommendations? in the Lighting Forum area at ElectriciansForums.net
I am looking into fitting some sort of recessed spotlights in quite a contemporary home. Ideally i would like them to be integrated, with a trimless finish. they will also need to be compatible for dimming.
anyone got any recommendations?
They won’t be cheap but try Mr Resistor (based in south London) they sell fancy light fittings etc
The only ones Ive used are called astro trimless. They were though a gu10 fitting and also needed to counter sink the screw holes as the plasterer complained that they couldn't get a good spread of plaster over the screw heads holding the fitting up.
Hi,
A popular solution with our customers are the Aurora Mpro LED Downlight with the trimless bezel.
You Install the bezel and plaster over it. Then fit the light afterwards once the decorating has been completed leaving a high quality finish.
The fittings are dimmable as standard and compatible with a large number of dimming solutions.
Cheers,
Ivan
Hi,
Cheers,
Ivan
I can vouch for the aurora ones, used them a few times..
Also Collingwood do one that takes their H2 pro fittings
Reply to recessed downlights - recommendations? in the Lighting Forum area at ElectriciansForums.net
I have purchased spotlights as below, but they are flickering when I dimmed them down to around 15-20%. We have installed 8 x ALUSSO LED Recessed...
Had a customer message me before I went to do a job asking if I could put a new bulb in a spotlight while I was there, so I picked up some LED...
Hi :) I'm currently renovating my outbuilding. My electrician has fitted 10 conduit LEDs (that support both leading and trailing edge) and x4...
Hi All, I have just installed 8x GU10 downlights in our kitchen with a 2 way setup using the 2 cable method, when I turned the light on they are...
Evening all, I've had a few discussions recently that have made me realise that I know nothing about lighting. Does anyone have any recommended...
