Discuss Recommendations for PAT machine anyone? in the UK Electrical Forum area at ElectriciansForums.net
T
The Ghost
Hi just wondering if anyone on here uses a PAT tester and feel any particular brand or particular PAT tester is better than any other? I use a Seaward Primetest 50 at the moment.
Yes definitely a pass fail meter. Which is fine I do small quantities. It is just today a landlord who I did an EICR for and some PATs' asked for a certificate because the letting agent want one. So the plug labels are not good enough. I suppose this will become a trend now. I was thinking downloadable but maybe not. Thanks for the tip not to go crazy.
I bought a second hand Seaward 300 which sings AND dances. I have it for the times it’s required - nice to have a bit of class that tests properly.
I have an old all singing all dancing Ethos (Seaward) too.
Not really worth the investment.
It downloads to the records automatically and gives bluetooth barcoded lables and automatically scans and records to the item numbers. I have not used it for ages , except for the earth leakage facility.
I used to use a Seaward Supernova and it was excelent. Currently using a Megger 420 and in my opinion it's nowhere near as good.
I have iPat which is really quite nice for a cert. I notice it has some figures you can put in which my lowly machine does not do or show. It is seeing the figures which makes me think I ought to get a better pat tester that does the Kva and so on.
We have a Robin SmartPAT 5000, which has just gone in for its 19th annual calibration! The download facility is great and easy to use, to produce certificates. Maybe worthing picking one up, if you're happy with an older model, they do sell on ebay sometime less than £100, obviously allow £30 for a calibration.
Just found a Robin 3000 on ebay for £75 it does look like a bit of kit. And I am a sucker for gadgets.
IIRC the 3000 does not store/download, so you have to record the results manually. Look for a 5000 or a 5500, the 5000 is better nowadays as it has a serial port, whereas the 5500 has a 3.5" floppy drive for data transfer.
Well guys, I only do basic stuff for landlords...so it's Pass or Fail...maximum number of appliances is about 20, so I don't need online downloads and all that fancy stuff. I do use an adapter for testing appliances that are hard wired through a connection unit or flex outlet, but for my limited use I am happy with my
http://www.pat-test-training.co.uk/micropat-tester-for-pat-testing/
which is cheap to have calibrated annually, fast turnaround, and is simply an easy way of ensuring compliance for landlords.
Not fancy, but simple...like me!
It is a moronic task compounded by low current earth bond tests. Second hand Supernovas can be pretty cheap, are downloadable and do high current earth bond tests which significantly speeds up testing. The negative is having a mains lead but you can buy extensions for the earth bond clip which are auto nulled
Reply to Recommendations for PAT machine anyone? in the UK Electrical Forum area at ElectriciansForums.net
Hi all, I'm looking at putting some warm white LED strip (3000k) in aluminium profile under some kitchen cabinets, so just looking for...
Hi , I have a KEWTECH smart pat portable appliance tester and KEWTECH KEW-80L bluetooth printer for sale due to change of job any one interested...
Hi Guys, just looking for a bit of advise. I am booked up to go on 2391-52 soon, and was looking at using my own tester, Megger1552. It is all...
Hi guys and gals, I have a question about the leads to computers (commonly known as kettle leads). I am new to PAT testing so please bear with...
Hi folks, Can anyone recommend a reliable brand for emergency lighting bulkheads please? I have a job coming up to replace 30 odd units. I have...
