Discuss Regs book at office in the UK Electrical Forum area at ElectriciansForums.net
Doomed
Looking at some work for a lady who has recently had a new fitted kitchen.
She was concerned about some bits so I had a quick look and found a 3.5KW oven on 1.5mm T&E to a 13A plug top.
Can anyone tell me the reg numbers for loads over 3KW needing thier own circuit, not using T&E into a plug top and for following manufacturers instuctions (and any others that may be wrong).
Thank you.
Cooking loads over 2kW should not be supplied from a ring according to a note in appendix 15, T&E is advised in the ISITEE guidelines as being unsuitable for a use in a plug becauce the cable is not designed for frequent movement. 134.1.1 and 510.3 "shall take account of manufacturers instructions".
Cable is suitable for the load.
Not to mention twin and earth into a plug top is proper badgers....
I have seen an entire brand new block of flats where all the fitted ovens were installed by the kitchen company on 1mm twin and earth via a plug top into a 13a socket directly behind the oven (no isolation switch) fed from a 40a radial in the board
Nice work fellas
Thank you
Nice work fellas
They are plugs NOT plug tops which are the covers for the plugs.
Reply to Regs book at office in the UK Electrical Forum area at ElectriciansForums.net
A friend of the family recently lost her husband to the big C so I need to be careful. Every small thing is sending her into tears so when her...
Ok i may get slated for this one but here goes; A bit of background info first. Its been a while since ive looked at my iee regs, and ive not...
I'm writing this mainly hoping something occurs to me while writing it! I got called to an occasionally tripping RCD. It's a Hager double height...
Hi, I've recently had my broken oven replaced in my flat and I paid for delivery and installation. It was hardwired through an unswitched plate...
