If I have 16 panels, each with an Voc of 30V and Isc of 8.37A and the irradiance is at 500Wm2 what is the equation to make sure the measured array Voc and Isc are roughly in the right area?
Also when measuring the Isc of the array what is the best way to conduct this test. I have seen someone shorting the array at the DC isolator in the off position placing the clamp meter around then turning the isolator on but got the impression this was presenting a hazard. Can it be avoided?
Thanks for your help
