Discuss relay question in the Electrical Wiring, Theories and Regulations area at ElectriciansForums.net
diditrain
I have an octal base 11 pin relay RS, from a boiler installation strip out. I dont use these in my every day work and am just curious as to the rating label. It states 230v 14mA.
Could someone please enlighten me to what this refers to.
Thank you very much
As above,, theres No way they would make a relay raited at 14ma for the contacts (unless it was tin foil) so this is no doupt the coil raiting. unusual to see the current raiting of the coil on it though...
Reply to relay question in the Electrical Wiring, Theories and Regulations area at ElectriciansForums.net
Background I live in Indonesia, the voltage for residential buildings ranges from 220 V to 230 V, I need help with the installation of the...
Hi there I have a few questions related to the power ratings of certain devices and how this interplays with the fuse. The reason I am asking...
Hi everyone Ive just had an electrical condition report conducted on a mixed-use property, and I am extremely surprised that after the last report...
I hope this is the right place to post this, please redirect me if not. I've spent quite some time reading the forums, so I apologize if I've...
I have a 230 Volt single-phase circuit with a 100 Amp cutout fuse and a 100 Amp MCB switch, so the supply is rated at 23 kVA. Only about 13% of...
6K
