Good morning -
I installed a subwoofer assembly in the trunk corner of my BMW 330 coupe.
It is bolted in, as securely as I could make it - and removing it is quite a chore ...
However, it also covers the access panel to my trunk mounted battery. I understand
that if/when I need to change the battery -- the whole thing will have to be removed.
But is there any alternative - like a remote kill switch - that I could install so that when
I work on the car and need pull the negative cable (for car audio, electrical, etc...) I would
not then have to pull the entire assembly out, just to get access to the negative cable/post ??
Appreciate any suggestions or counsel, and thank you.
