Discuss Remove bolt that is snapped of in brickwork? in the UK Electrical Forum area at ElectriciansForums.net
I forget the name of the bits we used on hardened steel , but there are a lot of quality bits available . As has been said , if possible centre punch to give the bit a start , use cutting oil and start with a small bit as I suggested earlier. It went in - it will come out with patience .
I take it this is a quality job and you cannot have an uneven line as @snowhead suggests.
I have seen a electric gate fitter weld a piece of metal on the end of a broken bolt before as the head had snapped off, as the piece of metal was quite long he could use a bit of leverage to turn it anti clockwise and free it up and unscrew it.
That's fine if there is enough to get a weld on to it. Another method is to hammer an oversize nut onto the stud and weld that to it.
masonry drill all round it in the concrete. get it out. refill with fine concrete mix. go back next day and re-drill for new bolt.
th
this might come handy .
Core drill around the outside of the bolt if you can't get it out by using HSS drills and a bolt extractor, then use one of those resin bolt kits to fix a stud in to the hole. Ignore baddegg as he doesn't have a sense of humour.........
Reply to Remove bolt that is snapped of in brickwork? in the UK Electrical Forum area at ElectriciansForums.net
Good afternoon all, I have been asked to look at a problem with a bolted neutral but no one seems to know what exactly is the problem. SSE...
I’ve always been alright with the knockouts provided for Fusebox consumer units but I’ve got a job coming up where I don’t want to use the large...
Long standing issue on my VW Transporter T4. First noticed under 'lockdown'. Battery drains flat if stood more that 3 - 4 days. Industrial spark's...
An old and now deceased friend's place has some rewirable fuses with asbestos flash pads. They are long overdue for replacement and now that seems...
Hi I've been planning to fit an outdoor junction box at the front of my house to hide a large brickwork hole and properly house the wiring...
