Discuss Remove bolt that is snapped of in brickwork? in the UK Electrical Forum area at ElectriciansForums.net
For anyone not yet sold on cobalt bits, I drilled a hole, through a drill bit! To prove it's not just some picture I found on the interweb, there's my username in the pics...
3.0mm split point HSS-Co bit into 12mm HSS-G...
This would be very impressive,if it was on the flutes.....
You have drilled it,in the soft part.....check if you want,using a file.
This is why you can file the pips and scuffs off,that slipping in a chuck causes.....but you don't use a file,for sharpening the same bit :)
You got two optomistics because not only did you post twice but it is very OPTOMISTIC seeing as the bolt snapped in the first place. Now if you could use the angle grinder to make a PZ3 then you might stand a chance!
Use angle grinder to cut a slit (north to south) in the bolt and use flat head screwdriver to remove bolt.
Thats cheating!
The shank of a drill is not hardened- try drilling the other end.
EDIT. see someone beat me too it with the hardness comment.
That's true, the cobalt bit could only make a small dent before I snapped the bit. Solid carbide drill bit, however.... :p
Fair play:) you seem like a man with similar interests,to me....
I'm just a little concerned,that they have given you tools and internet access......after what you did,at Hatton Garden....:rolleyes:
Reply to Remove bolt that is snapped of in brickwork? in the UK Electrical Forum area at ElectriciansForums.net
Good afternoon all, I have been asked to look at a problem with a bolted neutral but no one seems to know what exactly is the problem. SSE...
I’ve always been alright with the knockouts provided for Fusebox consumer units but I’ve got a job coming up where I don’t want to use the large...
Long standing issue on my VW Transporter T4. First noticed under 'lockdown'. Battery drains flat if stood more that 3 - 4 days. Industrial spark's...
An old and now deceased friend's place has some rewirable fuses with asbestos flash pads. They are long overdue for replacement and now that seems...
Hi I've been planning to fit an outdoor junction box at the front of my house to hide a large brickwork hole and properly house the wiring...
