Discuss removing alarm sensor in the Security Alarms, Door Entry and CCTV (Public) area at ElectriciansForums.net
M
Morgan keith
Hi guys. Just a quick one. Doing the electrical work on an extension and they used to have a garden shed with an alarm sensor in it. I want to remove the sensor from the system but wondering what's the correct way to do it. The sensor has a +,-, tamper and N.C in it. So do I just bridge out that sensor's N.C terminals in the alarm box and disconnect the rest? Used to work on the odd alarm in NZ but you had to put a resistor in the sensor circuits or bridge it out with a resistor but this one doesn't seem to have resistors? Cheers!!
If its on its own zone just disconnect from panel and fit a link to the Zone terminals and if it has an independent tamper then a link needs fitting to these terminals .... if you panel has a shared global tamper then disconnect the 2 tamper wires off the system and join together the 2 points that you disconnected it from.
A pic of panel terminals will help us to point out the correct action.
Cheers Darkwood! Haven't got a pic but I think from memory, the tampers from all the zones went into the same 2 connector blocks. So I'll disconnect the +, - and the tamper for that zone, and link out the zone terminals. Will take a pic tomorrow/fri if I can't get it sorted but think I've it covered. Many thanks mate!!
Reply to removing alarm sensor in the Security Alarms, Door Entry and CCTV (Public) area at ElectriciansForums.net
Hi, just wondering if anyone could help me. I’ve just installed a texecom Veritas alarm in my garage at home and can’t seem to get rid of the...
I currently have a home with 7 interconnected, hard-wired smoke detectors. I have a hard-wired heat alarm in the garage that I need to have...
On this commercial building we are refurbishing it has the above fire alarm panel which I think is pretty much brand new, I'm not even sure it was...
I’ve got a basic PIR motion sensor that I’m wiring into my garage just before the ceiling light. I’ve fitted it all fine and it works, however...
