Discuss Replace kitchen tube lights with LED lights in the DIY Electrical Advice area at ElectriciansForums.net
Hello,
I need some advice for a small DIY project to replace about 8 kitchen tube lights under the cabinets with LED lights.
Attached are some photos of the existing tube and power connections.
Can you recommend a LED lighting product that would be able to use the existing power connections of these old tube lights?
Any help appreciated!
Cheers,
Digby Head
Check these out at ScrewFix:-
Strip Lights | Kitchen Lighting | NoLinkingToThis - https://www.NoLinkingToThis/c/electrical-lighting/strip-lights/cat840982#category=cat840982&brand=robus
They appear to use the same connectors. I have one on my desk under a shelf and the connectors appear to be the same, as do the clips.
I have replaced quite a few of these fittings. Often the new fitting has very slightly different shaped connectors, and they don't quite fit. E.g. slightly squarer corners.
I've even bought fittings and extra leads from one wholesaler, where the leads didn't quite fit the new fittings, even though were "supposed" to be all the same range.
That said, often it is easy enough to replace the cabling, each fitting typically comes with a power lead.
Brilliant.
Not only do the replacement LED lights you recommended work. They also fit in the old brackets.
Took 10mins to swop.
Your advice allowed me to spend the rest of Sunday afternoon to do other important things: sitting down/watching tv. ;-) Thank you!
So in conclusion if you have Brackenheath kitchen cabinet lights they can be replaced with the Screwfix Robus range.
Brackenheath Lighting C21 6W 220-240V 50H >>> Robus LED Cabinet Strip Lights.
Brilliant.
Excellent :)
If you could reciprocate by suggesting a way in which I might get all my paperwork done so I can relax on a Sunday afternoon I'd greatly appreciate it :D
Nice and refreshing to see an problem solved and for the OP to come back and give good feedback
Reply to Replace kitchen tube lights with LED lights in the DIY Electrical Advice area at ElectriciansForums.net
I have three Aurora Fluorescent linkable (linked) under cabinet 'strip' lights (c.21cm each) under the kitchen cabinets and over the sink area...
Hi, I am restoring an old art deco, wall mount medicine cabinet. The cabinet has an 18” fluorescent light tube on each side. Before I put a lot...
We bought a house with an array of broken (some cosmetic issues, some functional) downlights under cupboards in our kitchen. The bulb seem to be...
One of the fluorescent tubes in my undermount lighting system burnt out. There are 3 independent tubes/ballasts under the length of the kitchen...
I am currently looking to add 12v led cob strip lights to my mother's kitchen but confused what I need. There are currently mains wires under the...
