- Reaction score
- 0
Discuss Replacement Singer oven element in the UK Electrical Forum area at ElectriciansForums.net
Thanks @Marvo - the location isn't so immediately apparent on my phone as it is on my PCThe OP has their location as Botswana so a supplier in Plymouth probably isn't going to be convenient.
I'm not sure who would supply it in Botswana but you could use TecsaReco in Joberg or Pretoria. If they don't have one off the shelf they'll manufacture one for you at a marginally higher cost. I'm not sure if they will deliver to Botswana or whether you'll have to get someone in SA to mail it to you.
Just for info that element is no way going to be 7.3 kW, looking at it's length and assuming a sensible tube heat density it's going to be around the 2kW mark....maybe 2.5 kW maximum. Maybe the entire stove could be 7.3kW.
Their range of domestic stove elements is here Stoves & Cookerhoods Elements: Bake, Grill & Warmer - https://www.tecsareco.co.za/stoves-and-cookerhoods/elements-bake-grill-and-warmer/41
Yes indeed i have, with no luck. Thank you for your reply, appreciated!I take you've Googled it, and or used on-line suppliers like e-spares?
You could give these folks a try:
Vanrigge Domestic Spares, Plymouth, PL4 0NH - DOMESTIC APPLIANCE SPARE PARTS - http://www.vanrigge.co.uk/
Reply to Replacement Singer oven element in the UK Electrical Forum area at ElectriciansForums.net
