Discuss REPLACING 2 GANG SWITCH FOR 1 GANG SWITCH UK SPEC in the The Welcome Forum area at ElectriciansForums.net
Hi
I could do with some advice/opinions on how to tackle changing 2 gang switch for a 1 gang switch
Basically the Kitchen has two lights on either end wired in a loop
circuit. Currently there is 2 gang switch working the two lights (not wired as a 2 way switch). Thus when you open the switch box you have 2 live wires etc, running out to each light etc.
I don't need a two way switch and want put both lights on one switch. Is it case of fitting a 1 gang switch and putting both feeds into the switch?, or is there a better way.
Please note that to wire the two lights together, I would have drill every ceiling joist due to the way they run across the kitchen
I appreciate this is a professional forum and I am not, however my electrician who checks the work is off two weeks, and I do really need to get things sorted.
Regards
Ben
Reply to REPLACING 2 GANG SWITCH FOR 1 GANG SWITCH UK SPEC in the The Welcome Forum area at ElectriciansForums.net
Hi, I’m looking to install 3 meross smart switches for 3 lights: entrance switch: only 1 gang but 3 way switch bedroom switch: 2 gang (1 is 1...
Hi, in my bedroom i had a 2 gang dimmer that powered 2 set of 3 spot lights and also had passthrough wires to other sockets. Im changing to just...
Hi all, currently doing a job at a house where there are 3 switches In the hallway to control the hall lights. All 1 gang switches, one at...
Hi, i’ve been trying to buy a smart switch 1 gang 1 way but i opened my conventional wall switch and i only have 1 red wire(Live Old UK) 1 black...
