Discuss replacing a cooker switch socket in the UK Electrical Forum area at ElectriciansForums.net
Yes you can replace the coker with a sock plate which brand will you be useing pringle socks are ok ,it will slip over nicely, there might be a sock plate behind the gas cooker you could fit a sock their has well .
Not sure they need to have 2, but with Click Mode it's pretty straight forward.Good luck getting 2 x 6mm cables into a 2G socket...
If one is the outgoing to the cooker outlet plate then you don't need to.
He will if that's how his gas hob ignition is connected!
OP is there anything still connected from the low level cooker outlet plate.He will if that's how his gas hob ignition is connected!
Reply to replacing a cooker switch socket in the UK Electrical Forum area at ElectriciansForums.net
