Discuss Replacing a sensor on an outside light. in the Electricians Jobs area at ElectriciansForums.net
Sorry - this is in the wanted forum. I need someone to do the work I am no good up a ladder.
Where do you live?Sorry - this is in the wanted forum. I need someone to do the work I am no good up a ladder.
Or you could get Prancer to stand close by and use him as a step up.@Santa in response to your original post, i assume that since you live at the north pole it would cost too much in diesel for us to come have a look and fix it for you, so if you go down the chimney, stop half way down and you will be able to come through the wall with a sds drill and scutch chisel. then replace the offending part.
Stick it on the chimmoThat's helpful, but I can't wait 'till Christmas as Mrs Santa insists that she need a light to find the front door
Do what?Stick it on the chimmo
Maybe a couple of elves on each others shoulders would be able to reach?Or you could get Prancer to stand close by and use him as a step up.
I tried but he is away.
Reply to Replacing a sensor on an outside light. in the Electricians Jobs area at ElectriciansForums.net
