Discuss Replacing Boiler's Spur Timer with Socket + plug in the DIY Electrical Advice area at ElectriciansForums.net
V
vt12
I have this boiler:
Ravenheat - CSI 85 combination boiler - atmospheric combustion - high efficiency boiler
~ If link does not show, google Ravenheat CSI 85 Combination Boiler - Atmospheric
The website says, under Technical Data, that the boiler is 3 amps.
My previous electrician installed this spur timer:
Masterplug Indoor Power TMIH24-MP 24-Hour Immersion Heater Segment Timer: Amazon.co.uk: DIY & Tools
~ If link does not show, google: Masterplug Indoor Power TMIH24-MP 24-Hour Immersion Heater Segment Timer
This timer is, however, rated to 13A.
Am I fine replacing this spur with a standard 13A plug socket? My instinct says yes but I have read that appliances should be fitted with appropriate fuses to prevent them causing fires in the event of malfunctions. I have a 5A or 13A plug that I intended to use for this purpose, but I would like to be sure.
I have only basic electrical and wiring knowledge so thanks in advance for replies.
why the hell has he fitted a timer? fit a fused connection unit (FCU) with a 3A fuse. isolate supply at consumer unit beforehand.
Hi VT12. Welcome to the forum.
I'm with Tel on this. I would love to know why your electrician fitted a timer.
Swap it for a fused connection unit (FCU) or switched fused connection unit with a 3A fuse.
Something like this MK 13A DP Switched Fused Connection Unit with Flex Outlet White | Switches & Sockets | NoLinkingToThis
Hum.. the sparky sounds a bit of a muppet. What fuse/MCB is protecting the circuit this is connected to?
Reply to Replacing Boiler's Spur Timer with Socket + plug in the DIY Electrical Advice area at ElectriciansForums.net
Good evening, I have recently moved into a new home and I am having problems with the MCB/RCD tripping (Mem M6 Type 3 - 30mA). It intermittently...
Hi, I’ve been living in a “new built” house for the last five years and the time to replace some of the built-in appliances has come. My...
4K
Toneyz
T
I recently came across some legacy lights which were taken off an un-fused spur which is part of a dual plug socket box. I have been unable to...
7K
I am planning a new layout for our utility room and would appreciate some advice. We have three appliances (washer, dryer and freezer) that will...
17K
Hi just after a bit of help ref a swap out as above for one of my builders at his home, He wants to replace gas boiler with an EHC 9kW...
13K
