Discuss Replacing fan controller for industrial extractor in the Canada area at ElectriciansForums.net
sivoodoo
Hi all, I dont normally do comercial but a friend wants two damaged fan controllers replacing, but I can not source the units. I will post a picture later when I go back, but what I am looking for is this:
Name on unit is: RAM
Specs on unit are: 0.2 - 10A. Serial number: sp5010A
Its a switch with, on, off and half speed, fixed after a DOL.
Any help on where I can get replacements would be greatly appreciated,
Cheers,
Do you know why the controllers need replacing, ie.. burnt / burning out motors putting too much load etc..
Im not sure about the RAM range of controllers, but i know of a perfect match (roof units sp5010) these are also 10 amp rated and are very reliable..
Do you know what size and make of fan it is?
Not sure yet what make, will have more information later, they need replacing as they have been broken, god knows how but something has fallen, been pushed against them.
Whats the make you refer to?
Hiya, from the pictures the speed controllers look like a discontinued model. They are single phase and electronic.
However, an alternative controller is the EFSC range.
EFSC 3 - 3 amp rated - £29
EFSC 6 - 6 amp rated - £45
EFSC 10 - 10 amp rated - £78
From the pictures i cannot see the rated amperage so you will have to decide on the required one, although as these are fitted with dol-starters i would suggest the EFSC6 or the EFSC10.
If your not sure on the amperage of the fan, you could always wire the fan direct and do a clamp check to find the FLC..
Take note though, these controllers can be 2 or 3 wire control.
Also when you power them up you will have to adjust a potentiometer on the back of the controller for the minimum speed voltage to prevent the fans from stalling on minimum speed.:)
Hope this helps.
Ps . the controllers can be supplied from cadamp.
Fan Speed Control, Fan Control, Controls, Heating Ventilation Controllers - CADAMP, UK, West, Yorkshire, Leeds
Thank you very much indeed Dan,
Good idea with the clamp meter, I trust I can pick your brains in the futer if I run into any problems?
I shall keep you updated.
Thanks again
Simon.
Here are the specs of the boxs:
sp5010A
220/240v
1ph - 50HZ
current 0.2 - 10A
so I'm thinking the 10A model?
Reply to Replacing fan controller for industrial extractor in the Canada area at ElectriciansForums.net
I'm sorry if this isn't in the right place but this is my first time using this forum. I'm also sorry if i make some mistakes but I'm new to this...
I have a ceiling fan which currently has a remote control for fan speed and dimming the attached lights. We're currently doing some works in the...
Hey everyone. Got a head scratcher for wiring a fan with a speed control with a run on timer on site today. I, and two spark could not get it...
Hey, I'm looking to smartify my extractor fans in toilets/bathrooms for two reasons really 1) I currently leave the light on the let the fans run...
5K
I have a bathroom extractor fan that has gone bad, so I need to replace it. If possible, I would like to just replace the motor, rather than...
Deleted member 105166
