Skindy
HiI was wondering if anyone can help me. I need to replace the the fuses for MCB's in a BMS control panel. Can this be done? And how would i go about doing this?Many thanks
Discuss Replacing fuses for MCB's in BMS control panel in the Canada area at ElectriciansForums.net
It may be that the panel is supplied by 415V 3 phase, however the circuits will not be.
Depending on the system, and the circuit lengths, they are most likely to be 24V or 230V.
It is possible that they could be 12V or 48V.
You need to establish the voltage of the circuits, and the resistance of the conductors, before considering changing the protective devices.
Reply to Replacing fuses for MCB's in BMS control panel in the Canada area at ElectriciansForums.net
