Discuss Replacing Light Switch for a Closet Light. in the UK Electrical Forum area at ElectriciansForums.net
You can’t install this switch without hiring an electrician to pull you a neutral but new code change in 2017 on new installation you have to pull a neutral to all light switches just for this ReasonHere is a picture of the original setup.
View attachment 51723View attachment 51723
I see one blue wire and one black wire.
Now, How would I about wiring this new Switch.
Any Help would be greatly appreciated!!
Tel the colors are black, red, white and green. The black or hot goes to black and the red goes to the light and you know the other wires. White is allways neutral unless marked with black tape where y’all use sleevesit appears that the new switch is 2 way. at a guess, i'd think black to black, brown to blue, block off grey. green is earth. but as it's american, i can only guess.
2k I looked at your picture and I see a white wire in the opening in the wall and that is your neutral black to black white to white blue to the red and since there appears to be no ground so just tape it up please tell me your not going to hook this up if you are not an electricianIt's a smart switch. Says "Neutral Wire required"... what is the worst that can happen if I do what you said? I would have to block off green as well. I don't see a green in there.
Reply to Replacing Light Switch for a Closet Light. in the UK Electrical Forum area at ElectriciansForums.net
