Discuss Replacing MCB's - Part 'P' notifiable? in the Electrical Wiring, Theories and Regulations area at ElectriciansForums.net
P
pmcsparks
As a semi-retired M.I.E.T. engineer, I'm wondering if replacing MCB's in a C/U counts as notifiable under Part 'P'.
Or is it non-notifiable as it's a like-for-like replacement as per first item in Table 1?
Replacement with the same rated item as a repair is not notifiable, but replacing an MCB with a higher rated item as part of a planned piece of work would be notifiable as it's not in the list of work that need not be notified in Part P. (Arguing that an MCB is an item of fixed electrical equipment is reading something into the regulations that isn't there.)
Reply to Replacing MCB's - Part 'P' notifiable? in the Electrical Wiring, Theories and Regulations area at ElectriciansForums.net
Hi all looking for some helpful advice I'm an Aussie so go easy on me, I have a good mechanical engineering head but first time plumbing and...
Hi all We've had some works done in our kitchen which has involved fitting a new cooker circuit, installing some downlights to replace ceiling...
Hi all, I have a light in the under stairs cupboard which is controlled by a switch in the hall. The under stairs cupboard is being taken...
Hi Folks , Just looking for a bit of advice as I'm looking to get back on the tools so please bare with me if this is a bit long winded. I'm a...
