Discuss Replacing (old) hard-wired LED strip in the Lighting Forum area at ElectriciansForums.net
Hi, I need to replace the "8w SMD LED" for a light in my rented apartment but there are 2 issues. firstly, I can't seem to find a replacement and secondly, it looks like it requires some hard wiring.
Saxby Lighting Ltd
Model 46395
Any advice on either of those points? Pictures attached.
Thanks!
Are you trying to find the parts to fix the old fitting or a complete identical new fitting?
Reply to Replacing (old) hard-wired LED strip in the Lighting Forum area at ElectriciansForums.net
As the title says. But then I cut off a jst connection off one of the light strips and I can't get them to work together... the one strip is plug...
Hey all, I'm not sure if I'm over thinking this, but I can't seem to find the answer to what I believe should be a simple question. I picked up...
Hi all I've been changing the halogen downlighters in my house to LED's. I have three rooms that use dimmers, two of them have two switches each...
Hello, We moved into our house 2 years ago and until recently the kitchen lights worked fine. The LED strip lights are on a dimmer switch, when...
Hey all, We have an RGB led strip behind a tiled wall , and lights a little shelf in the shower area. The RGB strip has become faulty probably...
