Discuss replacing panels/inverters tarrif payments affected? in the Solar PV Forum | Solar Panels Forum area at ElectriciansForums.net
P
provr6
Can anyone tell me the situation in the event that one or more of my panels fails (say 10 years down the line) can you use different panels with new serial no's and still get the tarrif ?
Same question if the inverter fails and I need a new one, will the fact its not the one registered with the FIT application affect the payments?
The inverter is not registered, as far as I understand, so no problems there, but the panels are, so if this situation were to arise my advice would be to keep quiet.
Who is going to go up on your roof and check them??
i would say as long as the wattage of the panel is the same and its MCS certified then whats the issue? inverters are not recorded on the MCS cert.
Replies make good sense. I thought I had read that inverters had to be registered and you should be wary of buying used ones off ebay in case they had been registered.
You are right though, my mcs cert just asks for the inverter model.
Secondhand equipment that makes up a 'system' cannot be used for a 'new' installation and get the Feed in Tariff. A system for those purposes has been defined by ofgem as including panels and inverter (not the mounting system or wiring :) )
However the Inverter is not registered as part of thes system for MCS / Feed in Tariff purposes :)
The Inverter make and model (serial number is NOT required) is registered with the DNO as it is the Inverter that is the SSEG. (We work with lots of DNO's and none has ever REQUIRED the serial number to be supplied)
Reply to replacing panels/inverters tarrif payments affected? in the Solar PV Forum | Solar Panels Forum area at ElectriciansForums.net
Hello there I have just installed a new Solis S6-GR1P3.6K-M-DC Inverter - this replaced a 10 year old+ Sungrow inverter that failed/out of...
Hi all, as per the above title. If one is to replace the existing solar pv panels for a new system of equal capacity (existing system is 8 x...
Hello All and happy new year. Over the holiay I have changed all of my old sockets to some nice new ones and added a couple with usb sockets for...
Hi all, total newbie to the forum. I sincerely hope that those in the know-how would be able to assist me. On my semi-detached house we have an...
Hi guys, I've gotten AI to write up a terms and conditions for my company and then went through it with AI and tweaked it to make it sound a...
