Discuss Replacing Pneumatic old time switches with electronic in the UK Electrical Forum area at ElectriciansForums.net
Massig
Hello,
I wanted to get an electrician to replace 3 x pneumatic time lag switches with electronic types.
Currently there are 2 lights and 3 switches...If you press more than one pneumatic switch the light stays on until the last switch runs out.
I wanted to buy the switches for the electrician and I am not sure whether I need to buy master / slaves ( 1 master 2 slaves) or a regular 2 wires all the same for all 3...
I was looking at this
TLSW 10 ILM - DANLERS Lighting Controls & HVAC Controls - https://www.danlers.co.uk/time-lag-switches/67-products/time-lag-switches/plated-time-lag-switches-2-wire-versions/107-tlsw-10-ilm
Also seen these
Illuminated Touch Timer - Timers and switches (Elkay switches and controls) | ABB - https://new.abb.com/low-voltage/products/lighting-emergency-lighting/lighting/elkay/timers-switches/illuminated-touch-timer but in the wiring instruction here can't see multiple 2 wires ... only shows slave / master.
I know my questions are probably stupid and i am doing the job myself - just wonder what to buy...
Also if any electrician in London Paddington is interested - let me know.
Let your electrician buy the correct materials.
Some of the electronic time switches require one master and several slaves. They are not necessarily a direct swop for the old pneumatic type. It will depend on how the wiring is laid out.
You are ‘buying them for the electrician’ but then you say you are doing the job yourself?
You then proceed to ask if there is an electrician in Paddington that may be interested?
What is it?
Just phone an electrician, tell him how many time lag switches you need replacing and he will turn up with them and install them.. job done, you don’t need to risk your health and others trying to carry out the work of professionals
What is it?
Sorry - typo ... I AM NOT doing the job myself...
Pneumatic light switches work with just about anything. Electronic replacements require much more thought, and careful selection will be required, especially if low energy lighting is installed.
The pneaumatic type are more reliable and also more robust to those people with heavy hands..
Another option would be to change them for retroactive switches wth a central lighting timer..
And another option; blank off existing switches and change the light fittings for sensor type
If you do go sensor switches be sure to get no neutral ones. Danlers work fine for what you describe. As to how many masters/slaves it depends on you switching arrangements. For instance a three way switch wants one master and two slaves and the three way wiring will need modification. For simple one way switches then a master for each one. Danlers are quite good for support if you have questions as well.
Reply to Replacing Pneumatic old time switches with electronic in the UK Electrical Forum area at ElectriciansForums.net
Evening Gents just after a bit of advice and what would you do differently. I have wired up 3 kw heaters in 4mm tuff cable (40 meter distance...
I have a Firebird oil boiler that is controlled by a Honeywell timer (no thermostat) that has channels for hot water and central heating...
DIY query Have narrowed down the source of an occasional trip to one light circuit which is a varilight v-pro master dimmer slave set up. This...
