Discuss Replacing push button with PIR in the UK Electrical Forum area at ElectriciansForums.net
Hello guys
I need to replace some push buttons wired in parallel with wall mounted PIRs.
Currently there is no neutral in place at the push buttons and I have been told the battery operated wall pirs are no good?
Is this true and if not can someone recommend something?
I normally take out the push buttons and replace fittings with an integral microwave sensor but they don’t want the lights changed
There are PIRs that don't require a neutral, whether they are suitable would depend on how much load you are talking. A search for "PIR no neutral" will give you some options that might work for you.
Reply to Replacing push button with PIR in the UK Electrical Forum area at ElectriciansForums.net
I have a baffling problem with a newly-installed PIR floodlight and I'd like advice from the forum as to whether it's defective (and should be...
I have a Firebird oil boiler that is controlled by a Honeywell timer (no thermostat) that has channels for hot water and central heating...
Im trying to make a Star Wars Prop for a course project where the dealine is comming up very fast in days and I need to do the report so really...
I am trying to find a replacement programmable thermostat to retrofit onto an existing installation, as the existing one has got a blank screen...
Hello. New member here. Electrical enthusiast. I am at a friend's house in the Bahamas and decided to look at the load center in the house, which...
