Discuss Replacing two-way switch with dimmer. in the DIY Electrical Advice area at ElectriciansForums.net
So, my set up is a little different to most people's. The switch I'm wanting to replace is a retractive switch, but the wiring behind the switch includes: yellow, black, blue, earth and a thick grey wire with a red stripe running the whole way down the middle.
I managed to get the dimmer working yesterday, however I could only turn the lights on and off from the same switch. The pull-cord by my bad wouldn't work. I swapped some wires around and put in the retractive switch again, but now it isn't working. I've replaced the dimmer switch as it needed to go back, but I'm just looking for some advice as to how it should all go together.
Is it even possible for me to have a two-way switch setup using a dimmer on one side and a pull-cord on the other? Where should each of the wires go, ideally? I know that there has to be a common wire, but the other light doesn't really show me anything!
This is the set up at the switch I’m replacing. Don’t worry - that isn’t how it was left!
Replacing two-way switch with dimmer. 918C9CC8-21FF-4795-9DFF-338CC824EBC4 - EletriciansForums.net
And this is the wiring at the other light, along with the dimmer terminals
Replacing two-way switch with dimmer. B0AEF6E5-B28F-4F13-87DC-07CEFAA759EA - EletriciansForums.net
Replacing two-way switch with dimmer. 315B57E0-8313-4085-924B-C7EDF9E403A0 - EletriciansForums.net
Replacing two-way switch with dimmer. image - EletriciansForums.net
What does it say about 2 way switching?
Your "thick grey with red stripe" is just a red with the grey sheath still attached. If you pull the cables out the wall a little, you'll see you have a twin-and-earth and a 3-core-and-earth.
Perfectly normal for a 2 way lighting circuit.
If the last pic there is your new dimmer, it doesn't look like a 2 way to me. It needs 3 terminals to be 2 way
Sorry, Murdoch. Go for it!
That little white sticker on the dimmer switch is the instructions it seems.
Should say how to wire it up.
In any case the thick grey cable with red bit down the middle really made me chuckle.
Maybe its all the cider i have drunk today.
I will say it as nobody else has.
Call a local electrician in.
It wont take more than half an hour to either tell you if your switches are suitable or if they arent then the solution and likely price.
But dont call on a sunday. That.might be a bit more expensive.
It's just irritating more than anything. It's supposed to be a pretty simple job, that for some reason is just proving to be a nightmare! I need to try and get the new switch in at some point very soon - I have no lights otherwise!
I didn't realise there was a third terminal behind the sticker.
Is it exactly the same as the switch you are replacing?
The new switch has an earth terminal on it. Use it for the earth conductors.
Connect the red and black of the twin cable to the 2 terminals on show. That will give you light over the weekend, but not 2 way operation.
Terminate the 3 core cables safely into separate connectors and leave in the box behind the switch.
Monday morning, call a pro. Is there no forum members could help out with a home visit?
Crikey, that fiestpic is it the finished connection, cus if it is you need to get an Electrician in to do the job prperly, come to that you need an Electrician any way.
Crikey, that firest pic is it the finished connection, cus if it is you need to get an Electrician in to do the job prperly, come to that you need an Electrician any way.
Don't berate yourself about the difficulty in this configuration. Two way and three way lighting is one of the stumbling blocks in learning electrics. It as always is easy if you know how. However it may require the help of an experienced spark.
that switch certainly looks as if it's only a 1 way. if so, it will never work.
Reply to Replacing two-way switch with dimmer. in the DIY Electrical Advice area at ElectriciansForums.net
