Discuss require 1 channel rf receiver?? in the UK Electrical Forum area at ElectriciansForums.net
Hi all, relatively new to the wireless stuff. looking for a smallish 1 channel 1000W switching unit to put into several individual enclosures to control outdoor lights in 6/7 different locations in a large outdoor space. Need to avoid wifi, need to operate from wireless range of around 200 - 350 metres, so figured something RF? mains in each location for power. Prefably able to operate from a smallish handheld or wall mount switch. Needs to be good quality!!!
Any product suggestions??? Thanks in advance 😀
Just posted this in another thread, so while it's on my tablet clipboard, have a copy (no personal interest in this product, just know it works well!)
(Remotes and other options available from this supplier)
You can of course add a contactor if the switching unit isn't man enough.
Thanks for the suggestion Avo 👌 Looks a great bit of kit. I was looking at their kit and found a few other options (something called a ferret -tiny 1 channel RF receiver with mains psu. could dot these about in individual locals, or use a RIOT receiver and chase cables back to central switching unit) then control either from a key fob or wireless gang switch.
Any experience with either?
FERRET - FERRET 1 CHANNEL MINI RECEIVER - 6-24Vdc - https://www.rfsolutions.co.uk/remote-control-systems-c9/ferret-1-channel-mini-receiver-6-24vdc-p905
RIOT T RX - RIoT 4 CHANNEL RECEIVER ONLY, 868MHz & Wi-Fi, 12-32Vdc and 230Vac - https://www.rfsolutions.co.uk/remote-control-systems-c9/riot-receiver-series-c337/riot-4-channel-receiver-only-868mhz-wi-fi-12-32vdc-and-230vac-p999
Reply to require 1 channel rf receiver?? in the UK Electrical Forum area at ElectriciansForums.net
Ferrets are known for being small, resourceful, and incredibly clever. They can solve many problems by fitting into tight spaces and doing jobs us...
Hi there. I'm building a house and need some help with the LED lighting design. Lots of experience wiring things, some experience using LEDs (did...
Hi all, I am building a portable workstation to hold 4 power tools IE: Router, Saw, Disc sander (Drill powered), Small Drill Press. The idea I...
F
With 8.5 KW of PV, two hot water cylinders and a meter spinning faster in reverse than it ever does forward it was obvious that something had to...
11K
H
Hardly used Flir Infracam for sale? About 4years old but only really been used on 1 contract once a year for about two weeks hence the reason for...
Hookie86
H
