Discuss Retrofit solution to solar powering an old large lampost in the Solar PV Forum | Solar Panels Forum area at ElectriciansForums.net
bigspark17
Could anyone recommend a set up i could use to power an old lampost using pv panel, charge controller, battery and BC led. The system would require some sort of dusk till dawn sensor or timer.
The lampost is in a very unaccessible location and cabling it underground is out of the question.
Could be a fun little project, i dont really want an adaptable box on the exterior but it could be used if small.
Ideas / kits sugestions welcomed
Reply to Retrofit solution to solar powering an old large lampost in the Solar PV Forum | Solar Panels Forum area at ElectriciansForums.net
I run a local charity raising cash to install defibrillators (AED's) around our small town in South Manchester - Most of the 14 we have installed...
LouiseIGC
L
I've just carried out a periodic inspection on a building on an old RAF/USAF site. Commercial single story building. Wiring system is around...
We had a PV/battery system was fitted in late May, and measurements showed it was working very well, but then a few weeks ago the old meter...
Hi All Planning an off-grid solar system and I’m pretty confident about most of it except for one thing - earthing. I believe the inverter I...
7K
R
Okay so I'm doing this project based on Arduino(which is a kind of microcontroller). The thing is, I'm a coder and don't really know a lot about...
