Hi all,
I, like many of you, have obviously faced the issue of routing cables through studs / noggins when the wall is already baorded - say for instance, adding a socket to a room or moving a light switch.
Now, some people use extension bars and make holes here and there and notch out and then make good.
Others use right angle chucks / drills
Some of you use other methods. Heck, maybe even remove the board, do the work and then re-board. Certainly more likely to neater.
I have battled this recently and had to resort to using a long auger and a right angled chuck, but I couldn't quite get to the bottom of the foot-plate of the stud, to get in tho the joists and had to cut a little channel below the socket cutout, thus making me have to make-good in the future once I had finished my first fix.
I don't like this, as it is extra work and looks ugly. Plus, time is money.
Now, I DID have, in the same kit as the right-angled chuck, a flexible drill extension thing. That had a large straight plastic handle to hold whilst drilling. This was awkward and only just fit through the socket cutout. But when I used it, it wound back on itself like a telephone cable that has been twisted like mad. It then snapped with the bit stuck in the base of the stud, so it took me 5 minutes to jiggle that out.
I was aware of the funky canadian tools flexible drill bit, but couldn't find anyoner in the UK that did something similar, until I happened across the fact that SuperRod made one. Another one is made by Greenlee.
I have just received my SuperRod one.
It's pretty cool and you can get extensions for it.
I haven't used it yet, but will be in the next few days. I will write a review of my experience.
First thoughts are that the drill bit is a little small, it seems to be about 12mm ish.
Watch this space for more of a review.
