Discuss Rewiring lighting circuit in the UK Electrical Forum area at ElectriciansForums.net
C
currie123
Hi guys
Wondered if anyone still uses the joint box method of Rewiring a lighting circuit?
For example on an occupied upstairs downstairs house where you are Rewiring upstairs lighting circuit using existing conduit drops to switches.
I am attempting to price such a job and reason I ask is I think I would struggle to get 3 1.5mm cables down the old conduit drops, obviously I can loop in at lights but with all these fancy fittings nowadays having 3 cables at the fittings is a pain!
If wiring using joint box method then it would be located in the loft space in a suitably accessible position, any thoughts?
Cheers
i would loop at the lights and where necessary use a line enclosure (see line products, forum sponsor) in the attic above the light/s. far easier and quicker than using screw terminal boxes.
Okay tel thanks what about wago boxes as opposed to line? Wagos are good not used line before yet.
Sounds okay I just can imagine having to use these boxes above 3/4 of the fittings which doesn't sound the best ?
We usually take it all (via clever pulling and use of trucking lids as rods) too a wiring centre full of push ins/ crimps, most cost effective way when it comes to too much laminate, loft junk and chipboard
wago boxes are fie, . also, as fin says, you could take several lights and switch wires to an adaptable box wiring centre and fit wagos in that.
Hi guys
Cheers
no....its nothing short of an atrocious method of wiring lighting systems....loads of cables stuffed into joints....joints inaccessable for inspection....just gets worse the more i think about it.....
can't beat a good bit of spider wiring with nothing marked and all cables buried under 2ft of itchy-poo. sorts the men out from the boys fault finding.
just been to one of them type of set ups...!!!
turned out to be a connector block that come loose...!!! stripped it out and replaced it with a click fitting i had in my pocket!!
lol.... better than connector block..! lol.. could not be bothered to walk to van and get wagos
Ha ha ok guys cheers i think il either go for the loop in at lights and joint above fittings as required with line or wago boxes if I get the job that is!
Reply to Rewiring lighting circuit in the UK Electrical Forum area at ElectriciansForums.net
Hi I have a job where customer has two families one families lives upstairs and one family will live downstairs. As the property is going through...
I have been asked to change cu from old fuse board which has 6 fuses. Only 4 fuses are used. The first fuse feeds cooker circuit. This is not used...
Hi guys I have some industrial lighting circuits to wire in a workshop and was after some fresh ideas/suggestions as to how i could best do this...
In a property with two consumer units one for the ring main etc., and the other for the 1970s storage heaters (storage heater CU looks like it’s...
