Discuss Ring circuit fault issue in the UK Electrical Forum area at ElectriciansForums.net
Hi.
Had a guy in yesterday to look at the tumble dryer and he told my wife he couldn’t work on it because the ring circuit of the house had a fault showing on his meter of over 2 ohms.
Wasn’t quite sure what this meant but I’m taking it as neutral to earth leakage???
I don’t really have any test gear but when I power off my board I see a continuity reading between earth and live wires. I then removed each earth one at a time and found that all this leakage was on my cooker circuit.
I then took out the cooker (which is plugged into a double socket) and still saw this leakage. My microwave is also on this socket and when I removed it the leakage was gone. A test of the plug of my microwave showed around 7 m ohms. Now this is done with just a fluke so no real voltage.
Could this be the cause of what he told my wife?
House testing isn’t something I do and just need guidance if the thought is that this is what he has picked up on because he ha cut the lead off the dryer and my wife now thinks the house will blow up!!!
Thanks in advance. Don’t really want to have to call in a sparky if it’s just. Bad microwave.
He cut the plug off your dryer because there was a fault on the house wiring?? If that is true then I wouldn't trust a word he says.
Also, the tests you are doing are haphazard at best, and aren't really proving anything. I would recommend getting an electrician in to do some proper testing of the ring circuit to put you and your wife's mind at rest.
Someone on here may be local. It shouldn't cost much. Keep us posted.
Liverpool is on my patch. as DPG's 1st para. the guy is an idiot. he's probably got a high ZS reading and is too thick to find out why. ( this aimed at OP's"electrician", not OP himself.
Most likely he is referring to earth fault loop impedance, depending on the type of incoming supply you have this could be either perfectly normal or a problem. Without knowing the type of incoming supply you have we can’t really comment further. If you post pictures of the incoming supply, meter and fuseboards we may be able to advise.
If he has cut the plug off of the appliance without your permission I would personally be bringing charges of criminal damage against the idiot.
I've come across this sort of thing on quite a few occasions where appliance 'engineers' refuse to connect something because 'it's over 2 ohms' or some other value plucked out of God knows where. Given that the earthing system or type of protective device are not taken into account you wonder what planet they come from.
My personal favourite was a call from an old lady worried because the Currys muppet had refused to connect her new cooker 'because half the fuseboard is new and half is old'. It turned out to be a 16th split main switch/RCD board. After a stroppy call to Currys they refunded her connection fee.
Hi.
Cut the lead off?? WTF! I’d be having words with him!
Reply to Ring circuit fault issue in the UK Electrical Forum area at ElectriciansForums.net
Hi guys. Having a weird problem in a house that has suddenly happened. One half of the ring main has 240ish volts (fluctuates of course), and...
Hi, Just been scratching my head about this one and wonder if I've missed anything. A few weeks ago I installed a new circuit for a 3kw oven and...
Hope you're all well . I've had ring door bell 2nd generation hardwired for 1.5 yrs... it was connected to transformer which is connected to the...
So was on a call out today and cooker circuit kept tripping the RCD. Disconnected at the board and at the cooker switch and IR’d the cable and...
