Discuss Ring Floodlight Installation in the UK Electrical Forum area at ElectriciansForums.net
Hello,
Long time lurker here, so thanks for all your advice in the past.
I'm due to install a ring floodlight on the rear of my property, which currently has no external power.
I plan on chasing an FCU in to the bedroom wall, fed off the upstairs ring final. This I plan on sticking a 5A fuse in to. I then plan on surface mounting rubber flex along the wall to the ring floodlight.
The problem is the floodlight only allows rear entry, the instructions mention using a 4inch round junction box to facilitate the cable run, then screwing the floodlight directly to this. However, I can't find anything suitable in width or IP rating.
Has anyone fitted one?
Any suggestions please?
Cheers
what i'd do in this situation is to chase a bit of mortar out at the bottom of the fitting so the cable can access rear entry.
nope. it's at the bottom water runs downhill. ask any plumber.
I stay away from rear entry, much prefer entry from the bottom. To the point I would return any rear entry only fitting. Most will have a few options.
Rear, top or side entry are to be avoided where possible.
Let physics work for you.
Reply to Ring Floodlight Installation in the UK Electrical Forum area at ElectriciansForums.net
Hey guys, looking for a bit of advise on the installation of an outside light. I plan on chasing out the plasterboard and running a cable from a...
Hello I’m going to install a hard wired 230v security camera, incorporating floodlights, outside and above garage door onto brick. An exposed...
I plan to add a socket to the existing ring main for a TV to be positioned on the centre of a wall about 1.6 m above the floor. To connect to an...
