Discuss Ring Main Continuity Test Help in the Periodic Inspection Reporting & Certification area at ElectriciansForums.net
C
clegg333
Hey I Was Wondering If Anyone Has Any Diagrams To Help Me Understand And Conduct The Test It Would Be Much Appriceated Thanks
P.S Sorry About The Bad Spelling And Grammer :p
yeah, try and be specific and we can tell you exactly, but really, as the guys said, its laid down in clear step by step stages in the OSG and GN3
breaker off socket taken off 3 continuity tests L - N - E respectively breaker on earth loop ;)
Adam do you not cross connect L-N, and then L-E to get your R1+R2, like what the book says?:rolleyes:
and what about your IR tests
oh, and I like the contravention of the EAWR's with your earth loop, nice touch;)
Well Im On The 2330 And Yesterday We Were Told We Needed To Learn How To Do The Test Because They Didnt Want Us Going In To Next Year Not Know It. We Were Given A Run Through On How To Do It But Alot Of Us Failed To Understand The Diagrams Were Confusing And He Completely Lost Me With The R1,N1 ect... Was Just Wondering If You Guys Could Explain Better.
Hi I am doing the 2330 level 2 and we have to check our ring circuits by :
first before connecting to the consumer unit we cross connect lives to earths then using a socket tester and meter check continuity between all the live and earth terminals and record them ( R1+R2) then disconect the cross over conections (L&E). we then have to do insulation tests at 500v across L and E, L and N and N and E.
From what I remember (sure if I am wrong someone will tell me)
Paul
Hi Clegg
Have you got the NICEIC Inspection, Testing and Certification book (£25) - very useful for testing and recording results?
Pages 224 to 227 attached http://aquae-vitae-electrical.com/htdocs/images/ContinuityTesting.pdf
This is dead testing - so main switch off - no just MCB
What you are trying to do is find resistance of the ring Live (phase), the ring Neutral and the ring CPC (ratio of 1:1:1.67 approx).
Then make a figure of 8 by cross-joining ring Live and Neutral at CU - this result is approx half R1 or RN.
Now do same with ring Live and ring CPC and test at various sockets in ring circuit (no need to remove accessories. As you can see from STep 4 you will get (R1 + R2)/4. This also confirms dead polarity.
good luck
Hi Clegg
good luck
Malc, maybe a typo
r1+r2 / 4 = R1+R2
where r1 = line loop resistance
r2 = cpc loop resistance
hey luke wasnt "if u build it they wil come" off a very old film? something about building a baseball field wi kevin costner????? cant remember what its called tho!!!!!
wel guys i have my402 exam in 6 wks n although the pysical side of it (installation of consumer unit, light 2x 2way switches, intermediate switch and 4 dbl ac outlets) isnt a problem im somewhat concerned about the working out of voltage drops across the system!!!!!! anyone any advice please??????
Got kitchers book , cant recommend enough pics are great calcs great dragged me kicking and screaming through my 2391-10 (at night school)
Reply to Ring Main Continuity Test Help in the Periodic Inspection Reporting & Certification area at ElectriciansForums.net
Hi guys. Having a weird problem in a house that has suddenly happened. One half of the ring main has 240ish volts (fluctuates of course), and...
Hi All Happy new year to all! First post but long timer lurker, so thanks for all the previous help! Just wanted to clarify something I have...
Good evening. Currently sorting out my girlfriend’s flat for rent. I’ve found all sorts of bad electrical work. Can anyone advise if this is an...
Ring main was on a c40 rcbo so I tested the circuit everything was fine and dropped down onto a b32, It’s quite a long circuit but only serves...
I am sure when I qualified for the 16 edition we spoke about how to treat a ring main. I know the majority of the time we just learned how to read...
14K
