Discuss Robin kts 1620 in the Periodic Inspection Reporting & Certification area at ElectriciansForums.net
I have a robin kts 1620 multifunction meter.The unit is not fitted with a d,lock when testing zs it will of cause trip the rcd protecting that circuit but not before i get a zs reading on the meter i have tried twice on both cycles 0 degrees and 180 degrees and they both give the same readings on there cycles can i trust this reading or should i:confused: do the onms law as well to confirm has anyone else got a robin meter and has any ideas can i have a d,lock put in or can you buy any accessorie to help??
Not sure you can mod any meter.
The only thing you can do is bridge out the RCD when doing your loop tests, or buy a meter with D Lok.
Reply to Robin kts 1620 in the Periodic Inspection Reporting & Certification area at ElectriciansForums.net
I've started to move over to AMD 2 forms for my CU installs, if only because the schedule is so much easier to tick and I can stop sticking labels...
Hi we have a split phase supply and had a EDMI ES-30B 3 phase meter fitted. Our readings are extraordinarily high. It is an old farmhouse but...
4K
Hello all, Looking for help here as I've come across a strange call-out today. Bare with me here: Got a call from a customer saying they had...
Hope this all makes as much sense as i can make of it and my "problem" can get sorted via some guru on here... Just a quick background on myself...
Hi guys & gals, I gave in and bought the new Megger MFT-X1. Got my hands on it Friday night, had a little play with it, used it at work on Monday...
