Discuss Rose Ceiling Light Wiring in the UK Electrical Forum area at ElectriciansForums.net
Hi All
I have a light fitting that i want to change in one of the rooms. Currently there is a rose ceiling light. I have changed a few of these but this room has some connections which i am not sure about.
I have some wago connectors ready but just want some advice before i start disconnecting.
which is the switch live in this photo? My Plan is to use some wago connectors to put these wires in and then use some flex cable to connect both sides.
The picture is attached with this thread. Any Advice is appreciated
The three reds in the loop in terminal into a connector on their own. The two blacks into a connector with the neutral of the new fitting. The yellow into a connector with the live of the new fitting, the yellow should ideally be sleeved red. Put the floating unconnected blue into a connector on its own as it probably serves no purpose. The earths into a connector along with one from the new fitting if it has one.
Reply to Rose Ceiling Light Wiring in the UK Electrical Forum area at ElectriciansForums.net
Hi All. I need to extend the cables for a 3 plate ceiling rose/pendant on ground floor ceiling by 450mm. Can I fix the ceiling rose/pendant to...
Hi, have an old bathroom fan. Which has two wires the black and red (line and neutral). The fan has no isolator switch and was powered when the...
Hi all was having a problem with lights work one min not next took ceiling rose cover off to find a stray black wire only terminal free is the...
1964 house old style wiring Need to wire a extractor fan up Is it possible to wire the extractor fan to report switch there's 2 red wires in the...
