Discuss round edge conduit surface boxes in the Electrical Tools and Products area at ElectriciansForums.net
Amp David
Mentor
Anyone know where or who stock surface patresses for use with pvc conduit, that have rounded corners?Have some grid switches to install and the face plates have the rounded edges, so don't want to use the standard square edge boxes to mount them as imo looks dog rough.
Moulded PVC back boxes, mashall tufflex, Mitre, MK all have round edge boxes, electricfix stock marshalls if I remember correctly if not most wholesalers will get it in for you.
Cheers mate, its just that i'm used to getting supplied the bog standard PVC boxes day in day out.
sure MK do them , to match their logik accessories. i --- ume you want the hi impact material ones. wouldn't fancy drilling a 20mm hole on the bog standard plastic rubbish.
Yeah, PVC rather than the brittle stuff a standard box is made from.
Just been looking and found the ones from uni volt and as local wholesaler sells uni volt conduit i'll get him to get some in
Reply to round edge conduit surface boxes in the Electrical Tools and Products area at ElectriciansForums.net
