Discuss Router in the Computer and Networking Forum area at ElectriciansForums.net
GPack
Hi,
I'm fairly new to networking so forgive me if this sounds a bit basic.
I'm trying to understand the limitations of ISP routers and when it may be necessary to upgrade to more professional router. Is there a good router package that offers reasonably priced wireless access points and switches you could recommend?
Thanks again for your help
Appreciated
Modem routers supplied by ISPs are generally as low a quality as they can get away with (though complaints have improved matters over time) so almost any other device would be an improvement.
Combined modem router access points are readily available at low cost and will often improve matters.
However the desired solution will depend on the requirements at the installation.
have a look on dd-wrt. its a open source alternative firmware to change your isp provided crappy router into something more capable.
Reply to Router in the Computer and Networking Forum area at ElectriciansForums.net
Hi all I’m after a bit of advice regarding wifi/secondary router. Data is not a strong point of mine so any advice would be very much...
Hi guys, I've gotten AI to write up a terms and conditions for my company and then went through it with AI and tweaked it to make it sound a...
Hi! I'm willing to build up a network within my residential house which includes outdoor equipment for WAN access. And I'm failing to figure out...
Hi All, This might be a bit of an odd question, I would really appreciate your thoughts. I am trying to up-date my mum's home, before putting it...
