Discuss running a cable in underfloor heating in the UK Electrical Forum area at ElectriciansForums.net
ExArmy
a kitchen island needs power to it for a double socket, apparently it has a flex with a plug on it, and you just need to plug it in somewhere. and as it'a an island it would mean pugging a socket in the middle of the floor. at the minute theres a blind of concrete on the floor, there is going to be 100mm insulation, underfloor heating pipes and then a 50mm screed on top. which will get quite hot, so obviously this will derate the cable alot i'm thinking it'd probably be best to run the cable from a FCU on the ring in probably 4mm in conduit to the floor socket but i havent done any calcs yet. how hot does underfloor heating get? will a normal floor socket be alright with the heat?
Use a metal clad socket , will handle heat better and wont get smashed up when fitted to the floor.
floor heating doesnt get that hot so 4mm in conduit should be fine.
Why couldn't you go underneath the celotex? You should have minimum heat there and your clear from the pipes and just JB onto the flex for the island.
well i've had to turn down the job anyway as i can't get it done within the timescale, but at least i know how to do it for next time now!
i was going to run it below the insulation, in theory it'd be pretty cool down there as 75mm insulation(to allow for the notch) is pretty good at "insulating" from the heat, and heat rises anyway. so in theory, if the only factor in derating is the fact that it's buried in thermal insulation for more than half a metre which halfs the CCC, so a 2.5 would be ok at 13.5A?
Reply to running a cable in underfloor heating in the UK Electrical Forum area at ElectriciansForums.net
Hello guys, It’s my first post here so please be gentle :) I’m having a kitchen extension done and will have the hob and few powerpoints...
Hi I have to run a feed to a CU in the middle of a ground floor flat . Its already got 2 layers of blue board and 100mm rockwool above it . It...
I'm looking at adding 100mm of sound insulation in an internal floor with 9x2" joists. The house has been rewired at some point so there are...
I am planning a rewire of our 1960s bungalow, for power sockets running cables under the floor. There is a 200mm floor void over a concrete...
Any recognised / best practice methods / conduit types for routing cables under floor. I’m looking to feed an island kitchen unit so will be...
10K
