Discuss Running cables horizontally along the 150mm top of wall in the UK Electrical Forum area at ElectriciansForums.net
n180
  1. Top of the wall – where the wall meets the ceiling there is a 150mm zone where cables should be run. It is at the top of the wall and runs horizontally around the whole wall
House is made of concrete floors. So I'm planning on using the top 150mm of wall (safe zone) by ceiling, to run cables horizontally. As it's not that common, is there anything else I need to consider like what if the kitchen fitter screws a screw somewhere there trying to fit a unit? Would you bother covering it with 3mm steel sheet (earthed)?
Is there something I'm missing, because i'm just wondering why people run cables in steel conduit when faced with concrete buildings, when the 150mm method is cheaper and quicker, safe, and meets the regs. Obviously there will be RCD protection.
Thanks in advance.
It's classed as an electrical zone so it is fine to run your cables there without mechanical protection. You're right in saying it's not often used so I would tell the kitchen fitter where you have put your cables and also tell the homeowner to cover (to a degree) future DIY projects.
Never liked these zones (I know they meet the regs) So I can see your concerns. I would take a minimum of taking a photo of the cables at 1st fix and emailing it to the client (and maybe the kitchen fitter) together with the illustration in the O.S.G.
if the floors are ceilings then the walls are more than likely reinforced concrete? Will be PITA to chase etc. how big is the kitchen? Could top hat/ceiling furring the ceiling and board it.
You would have to take in consideration the cables being more than 50mm from the surface.
So you would be notching 12.5mm or less out of the top hat of its a wooden batton you are referring to.
No I wouldn’t notch anything. If was doing the whole job or would discuss with the client about doing it the way I’ve mentioned....especially if the kitchen is being done, plastered etc. I would run the cables in one section then nail gun top hat to the concrete ceiling either side of the run of cables the plasterboard on top of the top hat.
Just run the cables where there isn’t going to be a join in the plaster board....so not at 1.2 or 2.4.
or surface mount cables within the 6" top of wall/s then fit coving or decorative trunking.
Yes, I can see that working, the cable being fixed so they would not come in contact with the steel edging or be where fixings would be.
Reply to Running cables horizontally along the 150mm top of wall in the UK Electrical Forum area at ElectriciansForums.net
Rewiring an old farm cottage… every wall brick and previous wiring not done well at all. I can’t locate any of the prescribed zones diagrams on...
Hi all, I'm planning to remove a stud wall seperating my dining room and kitchen. On the dining room side of the stud wall, there is a double...
Hi I've got an new outbuilding that needs power run out to it, the building is very close to the house and the original plan was to run an...
Hello I’m going to install a hard wired 230v security camera, incorporating floodlights, outside and above garage door onto brick. An exposed...
