Hi guys
my first post in here its probably common sense but here i go.
Im currently an apprentice maintenance electrician so domestic wiring i dont see too much of. My question is for my logbook. I have to run in a radial socket circuit. I know all the usual stuff B20A MCB 2.5mm cable clipped around under the floor etc. my question is how do i access the wall cavity of a timber frame wall with plasterboard on it from below the floor. Do i drill a 19mm hole up through the timber at an angle into the cavity?
Thanks guys any info appreciated im still learning & dont get much practice on domestic
