Had a CU upgrade just over a year ago but the electrician didn't upgrade the main bonding to the water from 6mm to 10mm. I don't know his reasoning, wasn't there for the work and never chased it up.
I'm having my garage converted so access to the CU is going to be restricted after the ceiling is boarded. Got a spark coming in to connect up new circuit to new detached garage soon so I've run some 10mm conduit cable around the outside of the house for him to connect up at the same time.
I want to clip this as low as possible and paint it but can't find any regs on what height from the floor it needs to be. Is it just common sense i.e not going to be whacked with a spade rather than a specific height?
Cheers,
Dan
Cheers,
Dan
